Bobcat Skidsteer Forums
Changigng Oil in My 753 Chain Case
Reply to thread
Message
<blockquote data-quote="7LBSSMALLIE" data-source="post: 51925" data-attributes="member: 6879"><p>every post are mostly correct. my onl issue is do not use the gaskets. they do not work. oil will wick out .i poly seal (dealer should have it) or quality silicone sealant, secondly it is not the drive motors leaking but the carrier seals, rarerly is the motor responsabile there are two reasons when it is the motor one bolts backed out wiping out seal vissable damage is apperent. two exessive case drain leakage in motor.rare but happens inspection of the case drain filters will usauly show it, or quit possibly the carrier brgs themselves. do remove center cover and inspect brake discs and carriers. bytheway the removal of steering console will make life eiser takes 10 min and placing a magnet in case below filler hole is not a bad idea.</p></blockquote><p></p>
[QUOTE="7LBSSMALLIE, post: 51925, member: 6879"] every post are mostly correct. my onl issue is do not use the gaskets. they do not work. oil will wick out .i poly seal (dealer should have it) or quality silicone sealant, secondly it is not the drive motors leaking but the carrier seals, rarerly is the motor responsabile there are two reasons when it is the motor one bolts backed out wiping out seal vissable damage is apperent. two exessive case drain leakage in motor.rare but happens inspection of the case drain filters will usauly show it, or quit possibly the carrier brgs themselves. do remove center cover and inspect brake discs and carriers. bytheway the removal of steering console will make life eiser takes 10 min and placing a magnet in case below filler hole is not a bad idea. [/QUOTE]
Verification
Post reply
