Caterpillar C3.3 Platinum Long Block for D-Series Loaders
**Caterpillar C3.3B Arr: 345-3550 Platinum Long Block for Caterpillar D-Series Skid Loaders and Track Loaders**
Emerald Power Solutions
(717) 354-6789
471 N Shirk Road
New Holland PA 17557
Our Platinum Long Block features new OEM Caterpillar components, including:
- Pistons and Rings
- Wrist Pins, Wrist Pin Bushings, and Cir Clips
- Main Bearings, Rod Bearings, and Thrust Bearings
- Oil Pump
- Thermostat
This engine is specifically designed for Caterpillar Skid Loaders and Track Loaders, but it can also fit many other applications. If you have any questions, please feel free to contact us for more details.
Our Platinum Remanufactured Long Blocks come with a 6-month unlimited-hour warranty.
Please note that because this is a Platinum Long Block, you will need to reuse some of your existing parts, including:
- Fuel System Components
- Injection Pump
- Injectors
- Injector Lines
- Exhaust Aftertreatment:
- Including DPF, etc.
- Turbo
- (We have remanufactured turbos in stock. Contact us to add one to your order.)
- Alternator and Starter
- ECU and wiring
Your Platinum Long Block will come with all necessary gaskets, seals, and washers for final assembly, and the valve lash is preset. All openings are capped or plated to prevent contamination during shipment and storage.
**Core Charge:**
A refundable core charge of $2,200 will be applied at the time of purchase.
**Core Criteria:**
The cylinder block must be unbroken and reusable.
**Shipping:**
The Platinum Long Block ships for free to anywhere in the lower 48 states. However, the buyer is responsible for the freight charge when returning the core. We can arrange the return shipping through our extensive LTL freight contacts and bill you accordingly. Please call us for a return shipping quote if you would like to proceed with that option.
