BrianCinNC
- Joined
- Apr 12, 2021
- Messages
- 2
I’m hoping someone has some input on a problem I’m having with my 2003 Cat 277 MTL. In the past few weeks my ignition fuse has blown a few times for no apparent reason while operating the machine. Today the machine died while operating just like other times when the fuse has blown (indicator lights all off, machine is dead), except this time the fuse wasn’t blown. It was hot however, and when I put it back in and turned the key to “run” for a moment it got warm again. I hit the socket with some contact cleaner and it doesn’t get hot any more. My first thought was that the problem was arcing causing a wire to overheat etc. But- if a wire overheated and shorted wouldn’t the fuse just blow again? So- before digging into the fuse panel I checked the ignition switch and found that the “start” terminal reads 7 volts? Shouldn’t this be 0 until it’s energized? I’m thinking there’s either a short on the wire to the starter relay or the relay has an internal short? Is my reasoning here sound? Any other ideas what it might be? Any suggestions are appreciated. . Thanks
