Cat 226 problem
snowjoker
My over ride light is stuck on for some reason. I know what its for, But not sure what the problem is. Occasionally I have hit the button on the joystick for the remotes, but have never used them . Anyone know which solenoid controls that function? I assume one of them is stuck ? Another question too, Would it be possible to put a "High Flow" pump on this machine ? its a 1999 model
skidsteer.ca
nobody knows ??
Sorry I have no experiene with Cat skidsteers.
As for the high flow, I have added one to a New Holland and am looking at doing the same to a Bobcat s185. Bobcat wants $2100 for the kit for this loader and 3 days or so labour to install
Which imo means if you can't do it yourself it s likely not worth doing compared to trading the loader.
No idea on the Cat either but the Bobcat requires a dealer only, reprogramining of the computer so the switch to activated it will work also.
As for the light it is likely a malfunction, as any activated functions should cancel by just turning the key off and restarting.
Hope that helps a little.
