85xt Case skidsteer would be running and then the engine would intermittently stop running. At one point I could turn it over and on or about the 6th try it would start again and run. Then it progressed to the problem where it wouldn't run or idle unless I held the ignition key on. If I let off of the key, the engine would die. Now it will not start at all. I have replaced all of the filters, in line filters, ignition, low pressure switch and now at a loss as to what to replace next. Looking for feedback
