Case 75 xt wont proppell itself
skidmark32
Hello good people, here's the problem... I changed the hose returning from the filter housing to the cooler and all was well for about ten minutes then the old girl started to fail. I had trouble trying to turn at first then it slowly lost power on the drives.... I replaced the oil with synthetic and tried again, no go. So I dumped the oil again and replaced with hyd 32 with additive from case and the filters, negative still wont hardly drive forward or back let alone turn, every time I push the joy sticks ahead or back the park light comes on and if the machine is idling with the bar down it is on as well until you throttle it up...?????? was wondering if maybe I got contamination in the swash plates or valve body.
