Other Brand Skidsteer Forums
Case Skidsteer Forum
Case 1840 Chain Install
Reply to thread
Message
<blockquote data-quote="goose" data-source="post: 33837" data-attributes="member: 1582"><p>The replacement chain on an 1840 does not have a masterlink, it is and endless chain. To replace the chain closest to the out side is not bad. Remove the center sprocket cover and the axle. Feed the chain over the center sprocket and roll the axle sprocket back and feed the chain onto it and reassemble. If it is the inside chain you will have to remoxe both axles and feed the chain to the inside sprocket.</p></blockquote><p></p>
[QUOTE="goose, post: 33837, member: 1582"] The replacement chain on an 1840 does not have a masterlink, it is and endless chain. To replace the chain closest to the out side is not bad. Remove the center sprocket cover and the axle. Feed the chain over the center sprocket and roll the axle sprocket back and feed the chain onto it and reassemble. If it is the inside chain you will have to remoxe both axles and feed the chain to the inside sprocket. [/QUOTE]
Verification
Post reply
