Ok I have a case 1835c with the 3 cylinder tmd 20 diesel motor. It recently developed a misfire and leak that I've pinpointed to the 'leak off hoses" on the injectors. From the top of the injector pump a small 'return' line goes to the first injector and then cylinders 1-2 are jumped together and cylinders 2-3 are jumped together. With the motor running or not that fitting on the top of the injector pump is pouring out fluid and I can't figure out why ?? My understanding was that the leak off lines were for unused fuel to return to the injector pump but the opposite is happening on mine. Any help is appreciated !
