case 1835b mid 80s wheel bearing install
sid vicious
need to change a wheelbearing[2 actually] on a case 1835b. anyone have a repair manual where they could email the steps? need to know the critical steps as wel as how tight to set chains etc. also,how much oil does each chain case hold etc? thanks in advance
I done this job a quite a few times on 18's and 17's and it is not too bad , you need to hope that the bearing didn't wollow out the end of the housing and ruin the axle as I have seen that too many times , the reason I seen this job so many times was they were using solid tires and tracks and the machine can't handle it , I have also seen where you should go ahead a do all 4 wheels as the other ones will be right behind and you don't want to wollow the housing , try and keep the string , rope , wire etc off the axle end as it seems to be a major factor in bearing failure as it gets into the seal and it don't take long from that point to see failure
