My 742B has always required a lot of pumping and full choke to start when cold, and even some choke to start when 'cool'. I just put a Walker rebuild kit into the carb . After re-installation, the engine started right up, but I have virtually no control over the RPMs. The engine races, choking it makes it worse, and moving the choke or throttle controls gives instant increase, but very slow or no decrease. In the course of the rebuild, I dismantled the components, cleaned them, and reassembled one at a time so as not to be overwhelmed by too many loose parts. Other than debris in the screen on the needle valve, there was no visible wear or damage. I replaced the needle valve and seat and checked the float level. I replaced the accelerator pump components with new, and the enrichment valve with new components. After removing the carb top, I dumped out the gas in the bowl, and saw the little weight in the pump discharge fall to the floor. I recovered it and noted how to reinstall correctly. I did not see the little ball fall out. In the reassembly I installed the ball that came with the kit. After the first experience with racing RPMs, I removed the carb and removed the ball thinking it wasn't intended to be in this model carb in the first place, but that didn't help. At one point I disconnected the throttle linkage from the governor, and that allowed the RPMs to settle down, but not correctly. If I manually forced the throttle plate closed, the RPMs declined more, but that isn't the solution. I believe I made an error with either the needle valve, accelerator pump or enrichment valve, since these are the only components which were replaced. Would greatly appreciate any suggestions about how to proceed. This unit is my snowplow, and there is more winter to come here in VT.
