Can't get Auxillary line past Lift arm Pivot Pin on 853
Rambler
Had to remove the auxillary iines to replace them. Was able to get one line to go up from the bottom area of the machine past the lift arm pivot pin to the metal tube on the arm that goes to the coupler , but can't get the other rubber line past the pivot pin to connect to the other metal tube on the arm. If I start the engine and lift the bucket to get more space at the pivot pin will hydraulic fluid come out the fittings where the rubber lines would normally be connected inside the machine or would Hydraulic fluid only come out those fittings if the auxillary hydraulics were activated? Any other suggestions? Thank you Greg
You'll only get flow if the aux is engaged, so you should be fine in raising it to get a better angle on the fitting.
