Bobcat Skidsteer Forums
Cannot get lower arm pin out
Reply to thread
Message
<blockquote data-quote="michaaell" data-source="post: 48664" data-attributes="member: 6408"><p>The black cylinder with the silver rod is what I need to remove so I can bring it to have a new seal put in. The top pin has been removed but the only way I see to remove the black cylinder is to remove the bottom pin holding the cylinder. The bottom pin is the one that will not move. Is this the correct way to do it? Thanks,</p></blockquote><p></p>
[QUOTE="michaaell, post: 48664, member: 6408"] The black cylinder with the silver rod is what I need to remove so I can bring it to have a new seal put in. The top pin has been removed but the only way I see to remove the black cylinder is to remove the bottom pin holding the cylinder. The bottom pin is the one that will not move. Is this the correct way to do it? Thanks, [/QUOTE]
Verification
Post reply
