CANBUS implement on a non-CANBUS machine
sniffy
Hi, I have a bobcat forestry mulcher with a ACD controller and 7-pin Canbus plug and I'm trying to use it on my NON-canbus skidsteer. How? This is the opposite of the usual situation.
Check with these folks to see if it can be done.
http://www.skidsteergenius.com/
I did and they didn't have an off the shelf solution at this time. They suggested that I remove all the solenoids and block the ports with plugs.
The 7 pin on a forestry head is for safety interlocks primary to insure the cab door is shut. I don't believe you have any other hydraulic functions besides spinning the motor. Even a bobcat skidsteer has to have the propper forestry kit installed before it can run the head. Contact a bobcat dealer with your information. A salesman should be able to do an easy cross reference. Bobcat company has an extensive listing on how to make bobcat attachments work on competitive machines down to correct hydraulic hose lengths.
