C190 sloppy steering
kvnnorden
I just purchased a 2010 C190 with 1800 hrs, after a full service and running it for 110 hours I noticed it is not nearly as fast as my 2007 model C190 when in fast mode, and the steering joystick doesn't respond as quickly. Yesterday while in slow speed I allowed the drive stick to return to the neutral position after moving forward and the machine kept going for about one foot. There is also a noticeable delay on both tracks but a little more on the left side. After you move the drive stick (left) there is about a 1.5 seconds however the machine works perfect other than this issue. Can anyone ahead some light on this issue?
*After you move the drive stick (left) there is about a 1.5 second DELAY however the machine works perfect other than this issue.
Is it cold where you are making it a little stiff maybe a bit of cleaning and lube
Yes it is cold here in NY however the machine response the same way when it is warm outside. I spoke with my parts supplier today and they gave me a couple of things to try. First I will switch the relief valves on the track drive motor to see if that makes the right side track slower to respond. If that doesn't do anything I will put plugs in the track drive motor ports and start the machine. According to my inside guy the engine should stall, if the pump is not leaking internally. If it doesn't the pump has warn internal parts and I will replace it. Either way I am told a lack of hydraulic flow is getting to the final drives.
