C185 wont move
RayC185
My C185 wont move, everything else works fine though, runs good, all the fluids were just changed a week ago. The bucket goes up and down properly its just when i try to move front or back it wont move. any help would be great
Sounds like your park brake is stuck on. When you try and move, does it fight you and make noises?
Not sure how the brake works on your machine, some use a solenoid and block to lock the drive system, others use hydraulics to lock the drive out.
I found the problem with my L185 to be the seat safety switch . The spade connectors were not making proper contact. I unfastened the connector and squeezed them both just a little, reconnected them and it worked great had full movement forward and reverse. Thanks to all those who replied.
