heedfarm89
- Joined
- Apr 15, 2023
- Messages
- 2
Just picked up a t190. It had some creep and the steering was super jumpy and jerky so I adjusted the neutral. The little roller cams looked fine, it appeared the blocks had already been flipped around but the 1 side wasn't bad at all so I switched them and got the neutral set perfect with no real trouble. Steering is still super jerky especially at higher rpm's. If you aren't careful it'll dang near buck you outta the seat. The machine sounds great, no squealing or abnormal noises. I checked the motor mounts and the all appear to still be tight. Where do I go from here?
