Bucket Plumbing LS160?
17821x
I've got a slow leak on the bucket hose on a NH LS160. It is about a 10' hose. The one end is on the inside of the boom. The other end is down in the frame at the valve I assume. Can this hose be replaced without jacking the cab?
The connection is under the fender. Just remove the two bolts holding the fender on and you will see the connection to the metal line from the control valve.
