bucket drop
rfgehp96
Have a New Holland LS185b skid steer with 1500 hours. I just changed the ram cylinders for the bucket tilt as they were leaking. I had bucket drop prior to this, and the bucket is still dropping after changing the ram seals. it is a fast bucket drop, with a load or no load. The ram cylinders are not leaking anymore. Is there a foot pedal cylinder for the bucket that could need looking at? I've also read about load check seals. Where are those located? Thank you for any help. Wayne
The load checks are on top of the valve in between the two ports. The only oring on the load checks is the one to seal the plug to the valve. There is also a plug on the back sdie of the valve above the spoot which has orings. The part could just be a plug or a valve depending on age, but those orings do fail occasionally.
