Generally its located on the port block. Look at the hydraulic pump, is there a square block on top of it with about 5 hoses coming from it? If so, it should be (if fitted) on the left side where there are three hoses. Remove the middle one and its fitting. This is where it hides!I assume your asking about the case drain filter?
