Acreage T250
- Joined
- Dec 21, 2022
- Messages
- 26
I got the T250 through my brother in law and got his crew to install a set of new tracks for $1300 Cdn. ea. When I received the unit , I noticed the left track seemed to be pointing outward but didn't give it much thought until the hydraulic pump seal went.
I'm in the process of pulling the motor and pump and decided to pull the new tracks off to get at the front engine mounts. I noticed the left track had some excessive clearance to the rollers, then noticed the grease tension cylinder had some grease leaking so purchased a seal kit.
After I got the tension assembly out, I was disappointed to see the spring cracked in a few locations, which explained the misaligned tracked and difficultly get the assembly out.
I know the spring assembly is technically not serviceable due to the 14000 spring tension, but has anyone had success getting a spring shop to make and install one?
