Bobcat Skidsteer Forums
Broken bolt removal
Reply to thread
Message
<blockquote data-quote="renopker" data-source="post: 54048" data-attributes="member: 2675"><p>I build the the bolt up with a tig weld then center a larger nut over the build up, then weld the nut on. The heat causes the threaded aria of the broken off bolt to expand against the sides of the hole so when the bolts cools it shrinks. Just after it starts to cool (looses it color) I put the wrench to it. I have taken out hundreds this way,along with taps never liked easy outs as they expand the bolt.</p></blockquote><p></p>
[QUOTE="renopker, post: 54048, member: 2675"] I build the the bolt up with a tig weld then center a larger nut over the build up, then weld the nut on. The heat causes the threaded aria of the broken off bolt to expand against the sides of the hole so when the bolts cools it shrinks. Just after it starts to cool (looses it color) I put the wrench to it. I have taken out hundreds this way,along with taps never liked easy outs as they expand the bolt. [/QUOTE]
Verification
Post reply
Broken bolt removal
