Bobcat Skidsteer Forums
broken a/c compressor fitting
Reply to thread
Message
<blockquote data-quote="mllud" data-source="post: 16211" data-attributes="member: 1012"><p>I would go to an a/c dealer. You might be able to adapt by using two fittings. It seems life there would be a combination of standard fittings too make an adaptation. You would probably need more clearance. If the old fittings were steel and the two halfs are still usable you could have someone braze them together.You said the hose stripped,that probably ruined the other threads. Mike</p></blockquote><p></p>
[QUOTE="mllud, post: 16211, member: 1012"] I would go to an a/c dealer. You might be able to adapt by using two fittings. It seems life there would be a combination of standard fittings too make an adaptation. You would probably need more clearance. If the old fittings were steel and the two halfs are still usable you could have someone braze them together.You said the hose stripped,that probably ruined the other threads. Mike [/QUOTE]
Verification
Post reply
