Bobcat Skidsteer Forums
Bought an M-610 Just Need a Little Help
Reply to thread
Message
<blockquote data-quote="Unicam" data-source="post: 99313" data-attributes="member: 13790"><p>with regard to your slipping belt. the issue i'm having with mine now is the driven sheave is hogged out on the jackshaft and the bushing is gone, also ate up the pins. this allows the sheave to wobble and provide a very poor surface for belt grip also not allowing proper side force on belt. when you take your belt off inspect the driven sheave bushings for deflection to ensure the sheave is opening squarely. also the 3 nuts provide preload and will add a measure of control as too the opening force required vs belt grip. hopefully this makes sense.</p></blockquote><p></p>
[QUOTE="Unicam, post: 99313, member: 13790"] with regard to your slipping belt. the issue i'm having with mine now is the driven sheave is hogged out on the jackshaft and the bushing is gone, also ate up the pins. this allows the sheave to wobble and provide a very poor surface for belt grip also not allowing proper side force on belt. when you take your belt off inspect the driven sheave bushings for deflection to ensure the sheave is opening squarely. also the 3 nuts provide preload and will add a measure of control as too the opening force required vs belt grip. hopefully this makes sense. [/QUOTE]
Verification
Post reply
