Bobtach Lever Handle sloppy Fit to bushing
JimH
On my T190, I'm tuning up things in the tilt and bobtach area. I notice that the welded-in bushing protruding from the bobtach mounting plate through the lever handle is less than 5/8 inch diameter while the hole in the lever handle is over 3/4 inch. It can only be seen when the handle retaining nut and spring are removed. My question is, should there be this much slop in the handle to bushing? It is a power bobtach and seems to work fine.
