bobcat753
Victorio
I was using my Bobcat yesterday when the tilt stopped working or barely worked. I had a leak coming from the right side for a month before. Should I add more hydraulic fluid to get the job done and if yes what kind? I purchased some Heavy Duty Tractor Fluid from Wal Mart but hesitant to put in in. Im thinking its a spool seal.
If you've ran it with the fluid low to the point that its affecting function then you may have damaged the pump. The tractor fluid should be fine. Put the fluid in, raise the cab, find and fix what's leaking before you do some serious damage to the pumps.
