Bobcat X125 Travel Motor Valve Block Copper Washer Leaking
Chris2006
Hi All
I have a year 1989 Bobcat X125 and the copper ring is leaking hydraulic fluid at travel motor valve block
Does anyone know the correct size for the copper washer?
The closest I can get is M18 but it wont go over the threads on the bolt
If you can't find the right size and the outer size is close, use a round file or dremel tool and ream it out. If it's not way off that is
