Bobcat Skidsteer Forums
Bobcat Trencher Question
Reply to thread
Message
<blockquote data-quote="Bobcatdan" data-source="post: 90255" data-attributes="member: 7339"><p>You could remove the female coupler on the trencher and run the hose in a bucket. Hook the male coupler to the skidsteer. You will pump your skidsteer hydraulic system empty doing this, but it will flush the trencher. If a guy is really worried, he could pull the trencher motor apart to see if it was the cause of the pump failure. I'll give the trencher the benefit of the doubt it wasn't the cause. Your reilef vavle was probably out of adjustment allowing too high of system pressure. Continuous use of a trencher put too high of a strain on the pump.</p></blockquote><p></p>
[QUOTE="Bobcatdan, post: 90255, member: 7339"] You could remove the female coupler on the trencher and run the hose in a bucket. Hook the male coupler to the skidsteer. You will pump your skidsteer hydraulic system empty doing this, but it will flush the trencher. If a guy is really worried, he could pull the trencher motor apart to see if it was the cause of the pump failure. I'll give the trencher the benefit of the doubt it wasn't the cause. Your reilef vavle was probably out of adjustment allowing too high of system pressure. Continuous use of a trencher put too high of a strain on the pump. [/QUOTE]
Verification
Post reply
