Bobcat T770 shutting down due to High Fuel Temperature
BCatT770
My new Bobcat T770 runs for about 15mins and High Fuel temperature warning comes up and the machine shuts down after about 5mins later with High Fuel Temperature. Help!!! Just got the machine and need to work to pay the bill
Never heard of high fuel temperature, i'd start by changing the fuel filter and see if it could be a restriction causing it to heat up.
Lowboy
Bobcat had a recall on the fuel temp sensor. They changed our sensor out under factory warranty.
Jacob
Fuel temp high on a machine, blowing off return lines. I checked return port flow and found the return line is making fuel pressure
Bailey54
I customer of mine has 3)T770 he leases. Bobcat has had several fuel related issues/Recalls. I know one being the wiring harness that runs off the high pressure pump. I would replace fuel filters and check the fuel lines down by the fuel/water separator for any kinks. I've seen the rubber lines bent/pitched off and build excessive pressure.
