Bobcat T770 hydraulic cooling fan.
tnek52
How can I speed up the cooling fan motor ? Running tree sawcauses hydraulics to run hot and overheat.
Not sure about the cooling fan, but is the oil cooler clean? A good pressure washing might help.
Oil cooler is clean. Fan runs but only speeds up when temp gets around 208 degrees. Have seen YouTube vidios where they wire in a switch to make the fan run full speed all the time while using forestry mulcher.
Might be a good investment, might help make the YouTube video make more sense.
Simply unplug the cooling fan motor solenoid, will throw a code but will run at full speed all the time.
