bobcat t770 code M3128
277Bobcat
I have a T770 bobcat that had code for SCR temp sensor fault. The engine would run fine and then would go into low idle mode after about 30 to 40 minutes. I put some new DEF and DEF cleaner in hoping this would fix the problem. Was running the machine yesterday grub some small cedar trees and machine suddenly died with last code being M3128. It will turn over the starter but will not even attempt to crank. There are no active codes when i try to start the machine. I ran fuses and found one blown 25 amp fuse F8 CAB ACC. replaced it but made no difference.
In a difficult recovery area.
277Bobcat
Thank you for the suggestion. Will definitely check connections. I tested fuse with electrical meter tester but I did not check the connections
