Bobcat T750 Fuel Pick up Tube
DBoehlein
Can anyone tell me how to get to the fuel pick up tube on a 2012 Bobcat T750? It is between the engine and hydro-static drive and I can not see it with the cab raised. Thanks in advance for any assistance. Don
It's not fun to get to, it's hiding under the engine.
I have never needed to swap one out with the engine in place, but i have heard it can be done. It screws in on the left side on the tank when looking from the rear of the machine. If you feel around on the left side and you should find it.
When you lift the cab, you'll need to remove the black plastic cover for the hydraulic fan.
Its very tight, I use a piece of plywood to lay on and hopefully you have long arms like me if not good luck or find someone with long arms. It can be done I have done a few but not fun at all
