Thanks for the info! I appreciate it!Additional part sources I use: LPS- loader parts source, Friday Parts. Competitive prices, decent quality, but I still buy some parts from Bobcat.
Thanks a lot! That was really helpful. We worked on it today and found out both sensors were disconnected probably by the previous owner. We connected them and added a lot more fuel since it was standing on a hill. Now it's running! Again, I appreciate your help!D7539 Left Swash Plate Sensor out of Range High
D7541 Right Swash Plate Sensor out of Range High
M0921 Fuel Level out of Range High
Check your Pump harness, pretty much in the middle under the cab. Has three Connectors going to the Main Frame Harness and on the other side going to the pump sensors. Probably rubbed through somewhere.
Same with your Fuel Sending unit. Behind the Battery is a Connector with 6 proms, depending on your machine set up, might only 2 be used. Fuel Sending unit should be in front of the pumps. Check the wiring most likely the unit it self
Check out River Fluid Power next time you’re browsing.Additional part sources I use: LPS- loader parts source, Friday Parts. Competitive prices, decent quality, but I still buy some parts from Bobcat.
