Bobcat T300 code 60-22
WVT300Bobcat
I have 2004 bobcat t300, the aux have stopped working. The light will light up when pressed when the engine is off but will not come on While running. Throwing code 60-22. Has anyone had this issue?
60-22 usually points me toward an electrical/control issue, not the hydraulic side. I’d start with the easy stuff first: check the aux/PWM fuse with a meter, inspect the plugs under the cab, and look for rubbed or corroded wires going to the aux controller/solenoids.
If the light works with the engine off but not running, I’d verify power and ground before buying parts.
Hi I’m having the same issue, did you ever come up with a solution?
I have finally fixed the issue! It was the left joystick. I guess consorted out in the joystick and was sending a fault for the rear aux. I swapped it out with another used joystick and bingo! Everything is working.
It ended up being a faulty left joystick
