bobcat t200 smokes
seal5610
put a remanufactured deutz 1011f engine in my bobcat t200 about a year ago. noticed a little smoke from the get go: asked my mechanic about it and he said just need to break in motor: problem has gotten worst where at idle it is smoking bad but at full throttle it clears up: it burns oil as i need to add a quart after running it for 10-15 hours. would my reman engine have bad rings; or piston.? could it be the turbo since i used my old turbo on the new engine. there is no oil blowing out the exhaust. also is there anywhere i can purchase a compression adapter for this engine. Rick
I'd suspect the turbo first, I'd like to thin that a reman engine was done right.
If you take the inlet and outlet hoses from the turbo off and see if it's wet.
That much oil use after 10-15 hrs is too high.
