Bobcat T-650 hydraulics quit
sweetwater5s9
2015 M-series. Nothing works, has oem fluid. Cab hydraulic needle drops to zero when any control lever is applied. Under 1100 hrs. Anyone else have this happen? Machine is useless but will run. Thanks for your help...
The first thing to check is the drive belt, if it slips, the engine will run, but will not move.
Happens more often that you'd think
Tazza, Thank you. I will check the drive belt as soon as I recover from the flu. I did have to replace the belt a short time ago and put about 15 hours on it before this happened. Will let you know what I find. Thank you again. Steve
Hopefully it's just loose.
I hope you get better soon, flu can be quite nasty.
