Bobcat starting problem.
bobccat
Hello
I have a problem with the bobcat s220, when you move it to the object it doesn't start, when you bring it back it starts every time.
if I turn it on directly from the starter, it starts. The ignition lock works without problems. Here is the question: could there be a fault in the hazard lights panel where the head connector and the ignition lock connector are connected, and would it be possible to test it somehow? this is a very chaotic and frustrating bug.maybe someone has experienced a similar problem and can advise
