Bobcat S650 starts then shuts off
Stump-Jumper
Howdy folks !
New to your group.
My s650 of 2012 starts up fine then seems to just shut itself off after a second or two, but will start again then die over and over again.
checked engine oil, Hyd oil, coolant, etc
M1403,m2403
M1403 Fuel Pull Output Error Off
M2403 Fuel Pull Relay Error Off
Check your wires around the Fuel Shut Off Solenoid. There might be even something wrong with the connector.
The machine is not pulling the Fuel Shutoff Solenoid back that's why your machine is dying right after start.
Thank you I will ! Have not been to ft worth in years, used to visit Richardson
Noticed a wire spliced into the Solenoid wire, guessing it supplies 12vdc.
Thnk you for the info!
Bryan
