Bobcat S595 steering
ckjohnson99
My two speed S595 seems to want to veer slightly left when both arms are fully forward. In order to go in a straight line (down the road to the neighbor's place), I have to hold the right arm slightly back which slows the machine down.
Is there an adjustment somewhere that I'm missing?
This problem could be caused by more than one thing. It could be linkage, a control that is going bad, internal wear in the pump, or a problem with the motor.
If you have mechanical controls, my advice is to start by inspecting your linkage to make sure they have the same travel mechanically. Also inspect the control lever for cracks.
If you have the selectable joysticks, it could be the control on top of the pump. Hopefully it isn't the joystick.
Finally...if it's the drive motor, the 2 speed shift could have issues. Does it act the same in high or low range?
Anyway, a few places to look at.
