Bobcat s250 blowing no heat or air
Dalooch
I have a 08 S250 with factory heat and air. What happens is it blows neutral air. Is there a valve that could be stuck? If so where’s it located Tia.
You may want to start with cleaning the cab air filters, heater and evaporator cores, and the air ducts. These cause a lot of heater and A/C problems.
Them are the ones behind the seat I’m guessing. Thanks I did remove them they didn’t look bad so I blown air through them and still no luck. Maybe I get new ones. It blows air good just not hot or cold when switching the thermostat
I’m just taking shots at the simple stuff. You could have a bad switch or a short or bad connection to it.
I had my windshield washer just quit for no reason. The connection was just a little corroded. Cleaned it up and it works fine now.
