Bobcat S220 dropping into snail mode
Boulderman
I have a 2008 Bobcat S220 that I use to plow snow. Tonight it started dropping into snail mode while driving in turtle mode. I can reset it by shutting it down and restarting but it continues to drop into snail mode. Any suggestions as to why this is suddenly happening?
i would perform a check on the switch itself switch connector and then trace the wiring looking for breaks/run through.
The problem turned out to be the Travel Speed Sensor Bobcat part number 6677181 which cost me $330.00 from Bobcat but it's only $50.00 online. I had to replace 2 of them.
Having the same issue on an A220. How do you access the travel speed sensors? What sort of job is it to change them? Any way to check them?
