Bobcat S175 hand pump vacuum
Do you mean that the hand primer is getting sucked flat? If so then either there's crud in the fuel tank clogging the fuel pick up or the line is getting pinched. Another thing is if it's very cold where you are and the fuel is gelled in the tank.
Thank you, i will reply when i got done whit cleaning.
If it works good till 1/4 tank I would check for debris in the tank blocking the pick up tube. Also check the primer bulb there is a flow arrow maybe got reversed.
If there is debris in the tank , how do i check, i can not look into the tank. Might blow it out? The thubes are thin it's hard for bigger debris to get through it. The the primer bulb flow arrow is in good direction. There is a small pump on the high pressure fuel pump It was replaced is brand new.
Most tanks have a drain. I would pull the pick up tube when it acts up to see if anything is in it. I had a 773 that I had to replace a lines to get it to work right. Blowing it out doesn't work because there is usually a check valve
