Bobcat Skidsteer Forums
Bobcat S150
Reply to thread
Message
<blockquote data-quote="rpmitch" data-source="post: 44581" data-attributes="member: 5846"><p>they do spring back to neutral but the lift arm creeps up by its self and same with the tilt down creeps also. When operating the pedals the lift up goes really fast then when you push down the arms still go up at normal rate until the pedal is fully depressed then it moves very slowly down (it may take 2-3 minutes to go all the way down). The tilt acts the same way. Before I got the lock to disengage on the sticks and there was a drag on the hydraulics the pedals worked perfect but as soon as the lock disengaged the pedals acted up. All that I can think is there might be something keeping the valves open in the body but I dont know</p></blockquote><p></p>
[QUOTE="rpmitch, post: 44581, member: 5846"] they do spring back to neutral but the lift arm creeps up by its self and same with the tilt down creeps also. When operating the pedals the lift up goes really fast then when you push down the arms still go up at normal rate until the pedal is fully depressed then it moves very slowly down (it may take 2-3 minutes to go all the way down). The tilt acts the same way. Before I got the lock to disengage on the sticks and there was a drag on the hydraulics the pedals worked perfect but as soon as the lock disengaged the pedals acted up. All that I can think is there might be something keeping the valves open in the body but I dont know [/QUOTE]
Verification
Post reply
Bobcat S150
