Bobcat S130 Electrical ?
Rentall
Looking for advice or a schematic for my S130. The upper right hand fuse (marked unswitched) blows every time I turn the key on. As a result I have no power going to the control panel on the left side board for the heater, wiper or accesory plug. We have checked all the wiring we can see and have nothing rubbing or exposed. Any ideas where to look?
It could be anywhere....
If you have a door, check the harness around it, even disconnect spots and see if it blows.
If you have a harness to the aux couplers, they tend to get knocked about and short out.
Essentially any point that the harness touches the frame, i know it's not a good spot to start, but a problem like that can be a pain in the butt to find.
I personally would try disconnecting everything possible, including the alt. Then slowly plug things back in till it pops again.
Is the heater on? It is not uncommon for the blower motor to lock up, that will blow the fuse right away. Also if you have a 7 pin harness on your machine and it happens to be smashed, unplug it back by the battery.
