Bobcat Oils and Fluids
crapola82
I have a 1999 bobcat. Anyone use anything other than fluids from the dealer? Are the hydro and other oils synthetic? I am not sure if I want to use stuff from the dealer or go to the local Fleet Farm ("farm supply" for those of you not near WI).
What model machine?
The new ones want genuine fluid, the older ones work just fine with motor oil, 15W40, 20W50 etc.
My choices are : Hydraulic oil in the tank and 15-40 Shell Rotella in the engine is my favorite , I have never been able to find 10 w 30 Rotella so 15-40 is the substitute , I am in the south where it really doesn't get too cold , motor oil in the hydraulic tank is no longer recomended by Bobcat as I have read in thier service bulletin that new motor oils have additives that are not compatable with hydraulic seals and components , and I have always found it is too thick and causes hydraulic code and warnings as motor oil is too thick , as far as synthetics in the hydraulic tank I feel it's a waste as leaks will occur , one blown hose can cost you all the oil in the tank and it is too expensive to waste like that , I see very few pumps go out and have been putting hydraulic oil in the tanks for the last 25 years , long before it was ok'ed by Bobcat , I was a service manager of an rental house that had 90% Bobcats products ,we had over 50 Bobcats in the fleet at all times , back in the day I was told we had more Bobcats than any rental house between Houston and Atlanta and never used motor oil in the hydraulic tanks , motor oil in the tank is a myth that will only cost you more money , as far as the chain case the cheapest motor oil 10-30 --------thats what I believe --------fishfiles
Thanks Tazza and Fishfiles for advice on 773 problems. I will let you know how I get on. Regarding oil question I had been using hydraulic oil in an old 743 which I had and when I bought a manual I noticed it said motor oil so I changed over. The 743 is quite old and has lots of hours but I can say that it ran better on the hydraulic oil before I changed over.
