BOBCAT MANUAL ACTUATOR CALIBRATION PROCEDURE: 1. Lower the safety bar 2. switch the drive to ISO 3. push the right joystick all the way forward and right with your right hand and hold it there 4. with your left hand put the ignition into RUN position 5. with your left hand press the green button (Press To Operate Loader) 6. let go the joystick If everything is OK you should get 32-24 code on the display which means that the calibration went good (if it did not please send the actuator to me, will give my mail address and cover the postal fee when you Private Message me). While calibrating you can also hear the electromotor move the slide valve to its extreme positions.
