Bobcat A220Turbo wont operate
Kosova
I cant move back or fowrward and i can;t lift bucket ,what can be wroung with that ,will anybody help me it's not showing any code on panel but wont just operate ,i can start thats all what i can do ,,,another things its like joysticks are not installed on this one at all
Sounds like a safety device, check your seat bar and seat switches. If they think no one is in the machine they will lock the arms out for safety. If they are ok, it could be as simple as a bad lock out solenoid on your control block.
I'm not sure if you rmachine has BICS or not, some have a box on your left side behind the seat with lights, they must all be lit for all functions to un-lock.
Ok, Engine running seat bar down you should have one light showing???(seat bar). when you push the green button the other three lights will come on???If not it may be the green button playing up( left hand pannel).This will not produce a code.A solonoid/coil or wiring fault with the joysticks will show up straight away.
Thank you for support i check solenoid and somhow now its operating but i have to play with ignition switch several times before i get this one to work.somwthing its more wroung than i was thinking it is ,do you know something more help me please , i spend most of day messing up with it and didnt work ,i feel like i want to put some gas on it and burn it
