Hi guys, looking for some help with an overheat issue I have been dealing with. The 963t has a perkins diesel. A friend and brought it to me with this issue. I was told the thermostat was replaced a month ago so I started with the water pump. I made sure the pump was working and even removed the thermostat to make sure that wasnt the problem. I bled the bleeder at the thermostat housing and ran the engine with the radiator cap off to make sure I got all the air out. Oh, I also blew the radiator out with a nozzle with a 1/2 inch hose. It appeared the water was circulating with the cap off but once I put the cap on and ran the machine for 20 to 30 minutes the guage went to the yellow. After shutting the machine the down I could hear the coolant boiling in the return hose. My conclusion is the radiator has to be blocked. This is my friends machine and I dont want him to spend money needlessly, so I just wanted to check with the someone more experienced. Thanks
