Bobcat 873 F Valve- green light
leonpona
Have problem with boom and backed , not moving at all . the green light indicating valve is off. where I should looking for the problem ? Please (-:
Your lift/tilt is not unlocking when you press the button?
It could be a bad stem on the control block, possibly even the coil, but usually that shows up as a blinking light to say something is wrong.
If the light is out, it is an electric problem, a the machine will not reconize a bad stem. Do you have a seat switch yet or the newer push to operate. Check fues first, this probably won't fix, but always start simple. If no light comes, I would lean towards a bad bics controler. If that is the problem, a puch to operate kit is cheaper then the controller alone.
AS FOR STARTING SIMPLE. check the bics fuse....
