Bobcat 863
Robanybody
Can a 2002 863 be converted from touch pad start, to a standard key switch to start the unit. I'm just not fond of the touch pad units. They're just too fragile.
Yes, you can convert a 2002 Bobcat 863 from a touchpad start to a standard key switch, but it may require some modifications. You'll need to rewire the ignition system and potentially replace some components to bypass the touchpad system. It's a bit of a project, so if you're not comfortable with electrical work, you might want to get a professional to handle it.
