Bobcat Skidsteer Forums
Bobcat 863 - Tapping/knocking and smoking engine
Reply to thread
Message
<blockquote data-quote="sstec" data-source="post: 56541" data-attributes="member: 5862"><p>I would pull the valve cover, quick and easy. See if push rods are bent. If so , timing belt. If not pull the head you see what you need from there. should take about an hour. sstec</p></blockquote><p></p>
[QUOTE="sstec, post: 56541, member: 5862"] I would pull the valve cover, quick and easy. See if push rods are bent. If so , timing belt. If not pull the head you see what you need from there. should take about an hour. sstec [/QUOTE]
Verification
Post reply
